do u mean u want to get an adapter for T15? (Plug into wall power socket and step down to required voltage type?)
If so, Bell systems (if i remember correctly) at SLT level 3, sells a Thoshiba one: 12V, 5A <$40. One shop in basement also sells a 12V 4A one, smaller in size, roughly same $.
For sale:
Modified ATX power supply unit.
Output 1:
Output voltage: 13.8 volts
Rated output current: 16 Amperes
Usage: This output can be use to supply RC battery chargers of any type. It can also be use to directly charge your sealed lead acid battery. Refer to the
Output 2:
Output voltage: 5 volts
Output current: 2
