Hi guys , i'm trying to charge a LiFe battery for my DX7 but i can't find the LiFe mode on my charger ( X605 Extreme charger ) . Is there any other battery setting that i can use for the LiFe battery to charge ?
Charger don't have LiFe charging .
Sure? Most chargers nowadays, even cheaper ones, can charge the range of lithium batteries: LiPo, LiIo and LiFe with different V/cell.Originally posted by TWE75 View PostHi guys , i'm trying to charge a LiFe battery for my DX7 but i can't find the LiFe mode on my charger ( X605 Extreme charger ) . Is there any other battery setting that i can use for the LiFe battery to charge ?
Supposedly, the X605 is a close copy of the Accucel-6, so this link to the manual might give you some info on how to access the LiFe charging function on your charger - that is, if it has the capability.
http://www.hobbyking.com/hobbyking/s..._manual(2).pdf------------------------------
yah he says he can;t fuind the function. if the charger does not have the function then use the LiPO setting BUT>.......disconnect the battery once you ready about 3.75V per cell. Won;t be perfect but it'll do the job for youOriginally posted by foxkilo View PostSure? Most chargers nowadays, even cheaper ones, can charge the range of lithium batteries: LiPo, LiIo and LiFe with different V/cell.
http://www.hobbyking.com/hobbyking/s..._manual(2).pdfRevo John
REVOLECTRIX Singapore
1090 Lower Delta Rd #03-01
Singapore
[url]www.revolectrix.com[/url]
