This is if you want your Lipo batteries to stay healthy and last longer.
Your Lipo battery voltage should not be discharged below 3.8V per cell at the end of a flight. If it is lower you need to reduce your flight time.
This means at the end of a flight,
for 3S, the battery voltage should be at least 11.4V
for 6S, the battery voltage should be at least 22.8V
In any case, do not let your Lipo battery discharge below 3.75V per cell.
If you are not going to use your battery for a while, you should charge/discharge the battery to about 3.95V per cell (i.e. for 11.9V for 3S and 23.7V for 6S).
