Batt can't charge please help!!!
    Can any one help me with the following problem?
    I can't charge my Li-polymer batttery cause the charger can't find any battery even the battery is connected to the charger and the charger keep flashing red led light that mean there is no batt found,with this problem I don't know which is at fault.
    PLEASE HELP.
    what charger are you using???
    If it's an apache...I think you've over discharged the cell...as such it falls below the min voltage for the charger to reconise anything...you cell is damaged....
    be careful if it bloats...and read the li po guidelines...
    TREX 500 ESP
    Futaba T12FGH
      charger
      Maybe your input amp too low
      没办法了,须改变自己,来试应环境。
        Hi
        It could be the battery connector problem. Poor contact. Some connectors are prone to this kinda problem.
        It could be your cells are damaged or you have selected a wrong settings on your charger.
        If your cells are below a min volt for the charger to charge, I think there is a method to 'force charge' the cells up to the min volt again. But this can be tricky & worst case may caused explosion. Suggest you read the charger manual carefully for this.
        Good luck....
