i am currently using a turnigy accucel 6 charger 50W. this charger has served me well by helping me charge hundreds of lipo packs already and all my packs are 3s 2200mah lipos. however, recently, i've decided to go bigger on my planes. bigger planes means better tx and rx system and bigger battery packs.
1. previously, i've been using dx6i with energizer batteries. how i've upgrade to futaba 8fg that i've bought overseas. my first problem is, the charger that comes with the futaba tx is rated input 120V 60Hz (which is different from singapore), output 8.7V DC 170mA. the battery on the 8fg NiMh is 7.2V 1700mAh.
2. i have also bought a second hand tx futaba T6EX for buddy box. however, it doesnt come with the charger. 6EX uses a NiCd 9.6V 600mAh.
3. i also notice that both transmitter has got something like a charging socket inbuild into it. however, both transmitter's socket are of different diameter. if i can find the correct size socket to be pluged into each transmitter directly from the charger. can i just charge the transmitter battery through the socket of the transmitter from the charger itself?
4. due to the battery that i will be purchasing. i think it should be around those 6s 3000mAh-5000mAh types. which means i should be using a charger with a capability to charge 22.2V x 3A = 66.6W to 22.2V x 5 = 111W.
5. i'm also a lazy fellow. charging one battery at a time is just too much of a hassle. so i'm looking those that can charge at least 2 or better 4 packs at the same time.
can u introduce me a charger that can satisfy all my requirements? thanks. any reviews regarding the turnigy 200W x 2 from HK website?
