Safe disposal of lipo in singapore
    Hi, wanted some advice on how to do it safely here.
    Thanks
    ** DISPOSAL OF LIPO BATTERIES **
    Unlike NiCd batteries, lithium-polymer batteries are environmentally friendly.
    For safety reasons, it’s best that LiPo cells be fully discharged before disposal (however, if physically damaged it is NOT recommended to discharge LiPo cells before disposal - see below for details). The batteries must also be cool before proceeding with disposal instructions. To dispose of LiPo cells and packs:
    1. If any LiPo cell in the pack has been physically damaged, resulting
    in a swollen cell or a split or tear in a cell’s foil covering, do NOT discharge the battery. Jump to step 5.
    2. Place the LiPo battery in a fireproof container or bucket of sand.
    3. Connect the battery to a LiPo discharger. Set the discharge cutoff
    voltage to the
    lowest possible value. Set the discharge current to a C/10 value, with “C” being the capacity rating of the pack. For example, the “1C” rating for a 1200mAh battery is 1.2A, and that battery’s C/10 current value is (1.2A / 10) can be used,
    such as a power resistor or set of light bulbs as long as the discharge current doesn’t exceed the C/10 value and cause an overheating condition.
    For LiPo packs rated at 7.4V and 11.1V , connect a 150 ohm resistor with a power rating of 2 watts (commonly found at Radio Shack)to the pack’s positive and negative terminals to safely discharge connecting it to an ESC/ motor system and allowing the motor to run indefinitely until no power remains to further cause the system to function.
    4. Discharge the battery until its voltage reaches 1.0V per cell or
    lower. For resistive load type discharges, discharge the battery for up to 24 hours.
    5. Submerse the battery into bucket or tub of salt water. This container should have a lid, but it should not need to be air-tight. Prepare a plastic container (do not use metal) of cold water. And mix in 1/2 cup of salt per gallon of water. Drop the battery into the salt water. Allow the battery to remain in the tub of salt water for at least 2 weeks.
    6. Remove the LiPo battery from the salt water, wrap it in newspaper or paper towels and place it in the normal trash. They are landfill safe.
    2013 RC4WD International Team Driver
      Thanks
      In short, this is what I've tried before and no problems:
      (1) Discharge your pack to 3.0V/cell (I think many chargers limit the lowest discharge voltage to this value for lipo)
      (2) Drain off the remaining voltage as much as possible using a load, e.g. I used an old brushed motor... just connect directly (+) and (-) terminal, no need ESC... but if your lipo is higher cell count, e.g. 6S... might be too much for a brushed motor to take.
      (3) After the above steps, your lipo will appear a bit puffy, no worries.
      (4) When the motor stops running, there's still some residual voltage left in the lipo. To totally drain it flat, expose the lipo terminals (carefully avoiding contact!) and immerse in salt water solution.
      (5) Once the chemical reaction stops (no more bubbles seen), the lipo is considered flat and may be disposed like normal trash. At this stage, even if it is pierced or terminals shorted together... nothing will happen as the energy has been totally drained.
      Of course, while doing steps (1) to (3), best to encase the lipo in a fire-proof bag or container, just in case.
        Thanks guys. Appreciate the advice.
