Guys i got a 6000mah lipo and one of the cell is lower then the other 2, abt 1.7v. Any advise on bringing back to normal? I tried charged it on nicad but only goes up to 2.7v and when i unplug it, it drop to 1.7v again.
Unbalance Lipo.
Originally posted by Mer78 View PostGuys i got a 6000mah lipo and one of the cell is lower then the other 2, abt 1.7v. Any advise on bringing back to normal? I tried charged it on nicad but only goes up to 2.7v and when i unplug it, it drop to 1.7v again.
Originally posted by Mer78 View PostGuys i got a 6000mah lipo and one of the cell is lower then the other 2, abt 1.7v. Any advise on bringing back to normal? I tried charged it on nicad but only goes up to 2.7v and when i unplug it, it drop to 1.7v again.Warpath Wong
Originally posted by Battle fury View PostWhat you are having is term as ' lazy cell'. Do this, balance charge it at 0.5 amps - 0.8amp(depends on your recommended charge rate, mine is 4.5A). it may take long hours to get 0.1V up. But you should see a slight improvement after a few cycles of discharging and charging. It works for me.
Originally posted by beefncake View Posthi bro,
u can try using those non-computerized balance charger. I dunnoe wad u call those charger but its e cheap type (nmlly included in RTF sets), charge 2S n 3S batteries only through e balancing connector and works by charging the cell in e lipo pack one by one.
Originally posted by hallobaby View PostI have tried and even save a dead cell...(lucky nothing happened)
From my experience, there is no point of using this lipo again.
It's already damage. My dead cell can not hold charge at all.
Fully charge 4.2 and next day will reach 3.6
Originally posted by Mer78 View PostWhere you get it from?
Originally posted by Mer78 View PostBecause my charger wont charge when the batt is not balance. Only nicab can I charge it.
1) Charge the LOWEST CELL by connecting the balance tab of THAT cell to your lipo charger & set the charger's settings to 1 cell. Don't have to plug in the deans. Just solely charge via the balancing tab. (MAKE SURE u understand the electrical circuit diagram of a 3 cell lipo before connecting the balancing tab, if not u will be charging the wrong cell or worse, putting u or the lipo at risk.
2) Charge that cell to the voltage that is similar to either 1 of the other 2 cell's voltage.
3) Charge all 3 cells as per normal n see if that cell return to normal 'life', otherwise that cell is gone.
Originally posted by jansonfinn View PostI did this method to salvage my dead cell before.
Originally posted by beefncake View PostI got one, the blue one from h o b b y k i n g, the other one the black one in the photo background was from my Sky Surfer RTF set. I can lend u if u wan as I seldom use it as for normal charging it takes very long time to complete. U will need a 12to18V min 5A output PSU to use it.
