Lipo Batteries. 10C 20C 30C 40C 50C?
    Hi all,
    Newbie here, i did a rough scan on first few pages and didnt see any similar questions.
    2200mah 3s 20C
    3s - 3 cells pack
    20C - Discharge ... but still dont understand?
    If i were to buy a rc plane, how do I know which C rating to get? 10C 20C 30C?
    Please advise Thanks
    got my answer here: http://radiocontrolzone.com/showthread.php?p=2462605
    What is C in relation to batteries?
    C ratings are simply a way of talking about charge and discharge rates for
    batteries.
    1C, = 1 time the rated mah capacity of the battery. So if you charge your
    650 mah pack at 1C, you charge it a 650 miliamps, or .650 amps.
    1C on a 1100 pack would be 1.1 amps.
    2 C on your 1100 pack would be 2.2 amps
    Motor batteries are often rated in Discharge C and charge C.
    So a 1100 mah pack (1.1 amp hour) might be rated for 10C discharge, so you
    can pull 11 amps ( flow ) without damaging the battery.
    Then it might be rated at 2C charge rate (flow), so you charge it at 2.2
    amps (2200 mah)
    How did I do? Things clearing up?
    If you have a 500 mah pack - any kind - and it is rated at 16C that means it
    can deliver 8 amps.
    If you have a 1000 mah pack - any kind - and it is rated at 8C that means it
    can deliver 8 amps.
    If you have a 1000 mah pack - any kind - and it is rated at 12C that means
    it can deliver 12 amps
    If you have a 1500 mah pack - any kind - and it is rate at 8C that means it
    can deliver 12 amps
    If you have a 1500 mah pack - any kind - and it is rated at 20 C that means
    it can deliver 30 amps.
    If you have a 3000 mah pack - any kind - and it is rated at 10 C that means
    So, if you need 12 amps you can use a pack with a higher C rating or a pack
    with a higher mah rating to get to needed amp delivery level.
      batteries.
      amps (2200 mah)
      can deliver 8 amps.
      can deliver 8 amps.
      can deliver 12 amps
      I still dont understand lol.
        Which part you don't understand?
        To simply put it, if you have a 20C 2200mAh (or 2.2Ah) battery, it can put out 44A. How I get this number is:
        2.2A X 20 = 44A.
        or for a 35C 1800mAH (or 1.8Ah) battery, it can put out 63A.
        1.8A X 35 = 63A.
          2.2A X 20 = 44A.
          1.8A X 35 = 63A.
          When you say Put Out? What does it mean in laymans term?
            There are video (youtube.com) talks abt C's in lipo battery, do check it out.
            Anyway I will strongly recomend below video (lipo danger...) do watch it.
