Charging Batteries in Parallel
    Hi
    Could anyone tell me where to get the cables and balancers to charge multiple lipos at one time in LHS.
    I dun think that lipo can be balance in parallel..
    I love PAP
      I came across this site and google the topic. Seems to be done quite extensively.
        If you're looking for something like the one in the picture. I don't think LHS sells them. I might be wrong. Simply because there are too many connectors to choose from, don't think it's profitable for them to hold something like that. It might be a better idea to make one yourself.
        Btw, you can balance lipo in parallel.
          Thanks, I tried looking at the lhs online and you're right, they don't carry it
          Ken
            Did a simple Y cable for both the charging cable and balancing cable. Ths way I can charge 2 batts in parallel. At the moment it take 2 times as long as my charging current is still 2A (power supply only rated 2A). If my power supply could support, I can charge the 2 X 2200mAh batt at 4.4A.
            At least now I can start charging and go do other stuff. No need to keep constantly check whether ready to charge the next batt.
            SG Fr3ak League : www.facebook.com/#!/groups/SG.Fr3aK.League
            BR Slopers : www.facebook.com/groups/BRslopers
              Originally posted by REVOJohn
              take a look at the MPA.....safe parrallel adaptor board...
              I'm looking at parallel charging my 6S..
              It's my first attempt at doing parallel charging..
              Please advise what I should do and what to look out for..
              thanks
              quest
              Avant Aurora (E1)
              Avant Aurora (E2)
              Mcp X
              GAUI X5
              LOGO 550SX
              WTS
                Safety first.
                As long as the packs are almost in the same state of charger and the same S count you can connect.............try the MPA boards as theey are designed to protection you incase you do something wrong
                It on out site
                but I'm using EC5 plug and the MPA boards are DEAN Plug
                Avant Aurora (E1)
                Avant Aurora (E2)
                Mcp X
                GAUI X5
                LOGO 550SX
                WTS
                  I bought the same thing from Derrick. Skyhobby Singapore.
                  I want to learn how to HOVER...lol
                  Training orientation MSRx with DX8 , Training up to TDR....Realflight 6.0
                  May Ah Pa bless me with the will to fly and stop buying Heli till i can hover...lol
                    yes we know. DEANS is the USA version.
                    We have the MPA with Si Wire for EC5 too
                    Arh....
                    It's in in April?..
                    Please PM me when stock are in..
                    thanks
                    quester
                    Avant Aurora (E1)
                    Avant Aurora (E2)
                    Mcp X
                    GAUI X5
                    LOGO 550SX
                    WTS
                      Oh..
                      did I solder this correctly for the board..
                      I have the female bullet on the battery.. but the male blue housing..
                      I was told this is the correct way of putting this EC5 together
                      What sort of balancing tab is this??
                      here is the picture
                      thanks
                      quest
                      Avant Aurora (E1)
                      Avant Aurora (E2)
                      Mcp X
                      GAUI X5
                      LOGO 550SX
                      WTS
                        Guys i just want to ask whether issit any or all lipo charger can support parallel charging through these kind of boards ?
                        And if i use 2 3s 2200mah lipo batt for my heli and one other 3s 2200mah lipo batt for my plane . End of the day can i charge them together one shot using parallel charging ? Cos my charger nowadays sometimes take more then 2 hr to balance charge a single 3s 2200mah lipo at 1c rate . Multiply by 3 = 6 hrs already . Not to mention sometimes i have other lipo batt to charge also . Take up one whole day already .
                          I have a generic made-in-china 50W charger, 5A max charge current, that I connect to a generic parallel charging board bought from HK.
                          At any one time I've plugged up to 3 pieces of 3s 2200 mAh for parellel charging, set to the max charging current. This is less than 1C charge rate and can take up to 2 hr, but at least I don't need to swap the lipos, and 3 pieces are charged at the same time.
                          The limit is usually your charger or your power supply max current for charging. Balancing, in my experience, is not so critical, where 3s is concerned. Might be a big deal for larger number of cells, though. Without balancing, the charge rate is faster, and some chargers even have a "Fast Charge" mode... slightly faster than usual.
                          If you still want to charge faster, then get a second charger, or third... Nowadays the generic made-in-china 50W - 80W chargers are cheap and good, with the convenience of being able to plug directly to 240VAC wall outlet.
                            I am using this at home charging.
                            2 cell of 3s 2200mah took me 1 hour
                            8 set will takes me 8 hours.
                            so you will have 16 pcs of fully charged 3s 2200mah or 8 pcs of 6s 2200mah for 8 hours without changing the batteries during charging.
                            and i use Revolectrix Cellpro 10S Lipo Charger for out field charging.
                            I love PAP
                              So how much is the Revolectric charger with the MPA ?
