hi guys...
i started this hobby with nitro planes.. then stopped coz racing 1/10 cars.. then now starting back but going into electrics.. but the problem is, all these motor and batt calculations are making me cuckoo... as i'm more familar with the more direct nitro concept..
so pls bear wit me and help me with the problems im facing. wanna get evrythg right before maidening my plane..
i jus got myself a green rc lipo batt for my jet. the specs are as follows:
2500mah
4s
14.8v
im planning to charge the batt using my previously owned macro power m6 charger tat i got wen in hk. sumthing like the imax b6
i'm aware tat each lipos have their own max threshold of charge rate setting. eg. max charge rate : 2c
correct me if i'm wrong, in evry intelligent charger, u are able to set the charge rate correct??
but in my case, my m6 lipo charge rate settings are in A (amp) example: my m6 can charge lipos at different current charge rate. ranging from 0.1A - 5.0A
so my problem is, how do i convert the "A" values to "C"? and my lipo batt doesnt display the maximum charge rate tat it can take.
so wat do i do now? i dun dare to charge it as afraid of overcharging it. wat is the safe charge rate for lipos in the value term "c". and how do i convert it to "A" amps?? im very confused now..
can somebody pls help me..?
and how do i calculate how long will it take to charge my lipo based on the charge rate setting??
another problem im facing is BEC issue. my jet is rtf. jus plug and play. comes wit a 45a esc. it says here jus need rx and batt to fly. does it means i do not need an external BEC?? to my understanding. the BEC is the component tat powers up the rx am i right??
i also read abt most inbuilt BEC (dat comes with the esc) cannot support polanes with more than 4 servos. is tat true?? my plane has 7 servos. does dat mean i need a BEC?? if so wat kind of BEC do i need to get. my radio tat im using currently is the sanwa rds8000.
one last qn. i thk my tx nicd batt is spoilt as the previous owner din use for quite some time. it gets drained easily. im planning to switch to lipo. are thr ani modifications i need to make so tat my tx can accept the lipo? or is it as easy as resoldering the terminals and get those tx lipo batts tat are easily available off the lhs??
i apologise if my thread is too lengthy. i jus wanna do it right the first time. many of u knw, alot of newbie give up coz of the discouraging results tat lead to crashes, electronics failure, jus coz of setting up the electronics wrongly.
im not new to flying. but new to electric flying. i dun wanna make my first time, a last time. i wanna last long in this hobby. so bear wit me and help me pls..
thx a million...
2500mah
4s
14.8v
thx a million...
