wat minimum amp for triton charger is recommended?
Question for triton charger
input: Voltage X current
can never exceed
output: voltage X current
So.. if you going to charge 3S, 11.1 V at 2A, then you need at least a 3A power supply. If you charge 8 cells i.e. 12 V at maybe 4 Amp.. then you wil need at least a 5 Amp...
Better get higher amp to account for other power used powering the fan etc etc... you won't want the triton to start complain about input current too low when the fan powers up etc.
Try getting something that is 7A and above.huh
