Hi Guys,
would like to find out if the Tahmazo T26 Charges Pb Battery as claimed in one of the Vender's website. I could not find the function in the Manual or in the equipment itself. Both the website and the box of the
Following is as stated: taken from http://shop.singahobby.com/?q=node/12057
Tahmazo T26 Active Power Charger
Tahmazo T26 Active Power charger with instructions
Tahmazo T26 'Active Power' is designed for the modern modelers, with a wide range of functions and engineered with the state-of-the-art technology. The Tahmazo T26 can charge NiMh, NiCad, Lithium and Lead-acid batteries, as well as discharge or cycle them to maximise their performance.
The Tahmazo T26 optimisation function will charge or cycle your NiMh or NiCad batteries using the latest technology to maximum your charge and performance of your batteries. With T26's 10 memory settings, you can select your favourite battery setting with just a click.
The other features of the Tahmazo T26 include:
* Capable of charger 1-26 cells Nicad/NiMh and 1-10 cells Lithium batteries and Pb battery
* Programmeable charge mode (discharge to charge or charge to discharge)
* Microprocessor "active" controlled charging and discharging
10 battery parameter memory for presetting your own charging preference *
* Thermal sensor
* LCD with backlight
* Fully adjustable charging current from 0.1A to 5A (in 100mA step)
* Fully adjustable discharging current from 0.1A to 5A (in 10mA step)
* Input voltage is 11 to 15vDC
* - Parameter includes battery type, current/capacity, charge current and discharge current
The safety features of the Tahmazo T26 include:
* Intelligent cooling fan control system
* Reverse polarity on input and output protection
Improper voltage input protection
Thermal overload protection
Pictures of the Tahmazo T26 Active Power charger
Tahmazo T26 connectors
Tahmazo T26 fan
Tahmazo T26 Temp Sensor
No. of NiMH/Nicad cells: 1-26
No. of Lipo cells: 1-10
Max Current(A): 5A
Input Voltage: 11-15v
Other battery types: Lead-Acid(PB)
Price: $298.30
I am very confused
* Thermal sensor
Tahmazo T26 fan
Max Current(A): 5A
Price: $298.30
I am very confused
