Hi guys, jus to check with u guys, if a lipo bloats after flight and goes back to normal when cooled, is that ok? What could be the problem that caused the bloat? The battery still has lots of punch.. Just that after flight, it'll bloat slightly.. Is that normal?
Bloating Lipos
i do it by trial & error method.Originally posted by john_3330Lets say for example the Lipo is 2200mAh 20C, how do i calculate my flight time? I am only flying it in idle mode for 4mins or less..
I will see how much mah charge in. 20% of the mah must be remained in ur batt b4 charging. U can adjust your flight time accordingly to it.
For amps drawn by the motor and esc im not really sure but im using the same set up as jansonfinn.. Align 430XL with 35X ESC.. I've heard before that the stock wooden blade by TT is very amp hungry right? So if i were to change blades, would there be a difference in the amp drawn?AR Drone 2.0
Walkera Ladybird Micro Quad
Jr XG8 Tx (Mode 1)
RG831B Rx
there is difference in the blades u use. Because of its weightOriginally posted by john_3330For amps drawn by the motor and esc im not really sure but im using the same set up as jansonfinn.. Align 430XL with 35X ESC.. I've heard before that the stock wooden blade by TT is very amp hungry right? So if i were to change blades, would there be a difference in the amp drawn?
