Anyone have these symptoms for these KP or any other batts
    Anyone have these symptoms for these KP or any other batts? I'm on less than 10-20 cycles, no bloat, no damage, no over discharge, only warm after flight. After full charge, all 3 cells are in almost perfect balance 4.19-4.20v. Set my HW30esc to high cutoff, which is around 3.2v. Only recently I notice after frequently measuring each cell, after like more than 5mins of non-stop flight till the esc cutoff took effect, all the cells become unbalanced quite badly ie. 3.28/3.35/3.40v. Balance charge`em gets back to normal 4.19-4.20v. Is it normal for these batts to unbalance every discharge? Thanks...
    Current Blink²:
    History Blink²:
    Belt-CP
    Walkera-#60
    Nate Waddoups
    bro u mean kong Power batts? if it does that.. it could be faulty cells liao..
    some cells have gotten "weaker" than the others.. try to bring in for some "warranty" if u bought recently..
    For sale
      ooo so this is not normal, will have to check 1st wit chuan. tankz broe...
      Current Blink²:
      History Blink²:
      Belt-CP
      Walkera-#60
      Nate Waddoups
        With 3.28/3.35/3.40 your total voltage at this stage is 10.03V.
        I would not venture into that discharge state. Lipo has a steep drop towards the end of the cycle.
        I usually end my flights at 11.2-11.4V. Battery lasts longer when treated gently. Plus my charging time is also reduced. I usually have 3-4 packs of the same kind to satisfy my needs.
        Other than the problematic bloating of earlier DN packs (manufacturing issue) I have no problems with my batts.
        Cheers,
        Leon
          quite agree... set a timer and minus off 1 min off ur flying time..
          mine is usually ard >11.3 after 4 mins flight in idle up
          For sale
            ooo, i tot setting the esc cut off to high is good enuff cos i saw many said not to go below 3v per/cell. so i stay at 3.2v each. Will set the timer on my tx to 4mins, tankz broes...
            Current Blink²:
            History Blink²:
            Belt-CP
            Walkera-#60
            Nate Waddoups
              hmm i think u can fly for abt 7mins if rpm not too high...
              btw nowadays, i set mine to cut off at 8.5V(note below 3/cell) to prevent softcut from being triggered in mid flight during heavy punches..
              timer is now my only defense against over discharging
              For sale
