May I know what type of Battery is suitable for HB beside the original one ?
Can I use Li-po 7.4V 1200mAH or Can i use 11.1V Batteries.
Thanks for the HELP !
As for mah....higher better as long as it is not too heavy. Higher mah gives longer flight time. Considering a suitable weight, i think the highest u can get is around 1320mah.....
must use 2s 7.4v. I use 3E 7.4v 2s 800 & 1200 Mah. works well especially 800 Mah one-very light. But when i use 1200 Mah is almost the same with stock batt lighter by 5-8gr maybe? but can last 12 minutes hovering.
Mini Titan E325
Dualsky XController 40A
Dualsky XMotor XM2834CH-8
GY240
Charger & Tx
Tahmazo T15-AC with T6B Balancer
Hitec Optic 6 Electron(given to other user)
No TX at the moment
