Kokam Super High Discharge LiPo 2000mAh 3 Cells
    Has anyone used this lipo. Are they stable? (the details were from thathobbyshop web) Thanks.
    Kokam Super High Discharge LiPo 2000mAh 3 Cells SGD128.00
    3 cell series (11.1V), heatshrunk with DNS connector, super high discharge (15C / 90%)
    Size: 80mmH x 45mmW x 26mmT
    Weight: 173 grams
    Ratings: 15C / 90%
    Outputs: 11.1V Nominal, 2000 mAh
    Similar post to PhiBer for kokam's 20C selling at SHS.
    The question will be how good is it. Guess the only way to try is to someone purchase it and do a stress test on it.
    Super-Hornet
      EH, ur this one lousy!
      SHS one 20C, even more power!!
        mechplas,
        If you're looking for good lipos, PM me, I can direct you.
          Those cells are not bad, if in 3s config, there should be air gap between the cells otherwise the centre cell will cook.
          The Super high discharge Kokam will discharge higher than their C ratings. But it will overheat and kill itself. To prevent cell self destruction, make sure the esc max cont. amps is lower or equal to the batt cont discharge rate.
