TP Battery Dying?
    TP Battery Dying?
    I have a pc of TP 2200 battery tat can takes ages (> 2 to 4hrs) to charge and balance. Is it dying? Time to replace? Bat abt 6 mths old.
    I have no issue with the rest of my TP batteries.
    In politics, there are no permanent friends or enemies only permanent interest - Lord Palmerston
    Are you using the iMAX for the balance charge? It will take quite some time, infact it's pretty long. Not sure how the processor/algorithm detects it's peak.
    A weak lipo is when you noticed your flight time has dropped considerably or can't hold a charge for long.
    Are the rest of the TP batts quite new?
      Well, this pc of battery takes unusually long on both of my T15 and imax charger. The rest no issues. Even flight time drops by 50%. 5 minutes flight at most (hovering) while the rest of my bat can sustain abt 12 min.
      RIP TP 2200mah battery...
      TP extreme, here i come!!
        hey mate,
        have you tried conditioning the batt? how many discharges did the batt have? what is the typical discharge C? sometimes when conditioning the batt you might get some of its power back.. albeit not for too long though. of course if you have like 100-150 discharges on it then .. uuummm R.I.P batt.
        Powder, Anyone????
          could be possible one or more of the cells is half dead. which could explian the long time required to make them "active" again... prob will be good to use them for something less critical....
