I can get 10A discharge on my ICE when I need to dump my 6cells IB4200 NiMh packs (who discharges NiMh at anything less than 30A anyway) but the lipo discharge mode only allows a 2C discharge rate ....i.e: cannot set higher than 4.4A when discharging a 2200 Mah lipo pack.
you can only get 7.42 amps cos your battery can only put out that amount at that point in time. if you discharge a pack that was just charged, 10 amps shouldn't be a problem.
Thanks..that makes sense... maybe my packs are old and not pushing that many amps
Okay ...You should be able to get 10A unless the pack is totally discharged
Could you have selected the "Auto" discharge setting instead of the "Normal" discharge setting ? .....Auto setting gives weird results and I never use it.
