Just curious guys, do you charge via dean or by balancing?
If I ensure all the 3 cells are balanced to 0.02V difference, then dean charge should be good enough right?
Bro...charge with the Dean, then sometimes check the voltage with the balancer connection, if out of balance then charge them using this connection.
Not necessary to balance and charge everytime.
More impt is to manage your amp draw and not to overfly the time given.
Hmm... guys, can confirm this Imax got discharge function? The datasheet doesnt seem to state. But I notice when I use " balance charge ", if I monitor the cells, the " Dchg" will appear when the cells are uneven and the voltage will drop... hmmm....
anyway for this lipo. Can state how much mAh i charge in!
Nope...imax5 don't have discharge function.
The "Dchg" is to balance out the cells.
This is a good and reasonable price charger.
Not only can balance charge LIPO, it can also charge PB and NiMH.
Money worth..
I read through few site's spec on the Imax B5 and found this
" Current drain for balancing Li-po: 200mAh/cell ",
correct me if I'm wrong, but draining current means discharging right??
i would interpret is as yes.....but the "discharge" is more or less auto and it works only when using balance charge mode.
Ok next I am going to try to use Lipo Charge instead of Balance Charge, using Dean connectors or Jst connectors. Pls correct me if I"m wrong below
1. If lipo is unbalance say 4.0V / 4.05V / 4.0V, and I charge it using dean.
2. The centre lipo will overcharge as to meet the 12.6V cutoff, the outcome will be, if all cells at even current charge, be 4.183V / 4.233V / 4.183V.
3. This means the 2nd cell will be overcharged while the 1st & 3rd will be undercharged.
Meaning, we must ensure all the cells are even voltage before using dean to charge. But even if it is even, IF the charge's measurement is inaccurate, it may reflect certain cell as lower or higher in voltage, resulting in cells being overcharged to reach the 12.6V cutoff.
