DN Lipo Charger
    DN Lipo Charger
    is anyone using the above mentioned? Was wondering if it's a balance charger or is there one normal and another model being the balance charger? Was surfing ard and the shops in HK calls it a balance charger but the local shops jus state as lipo charger.However the pics both looks the same. Anyone using can enlighten me? Also, can the charging AMPs be set?
    Kyosho Inferno Neo Race Spec
    Normally a balance charger should have inlets for the balance connector on the lipos. You are balance charging by using them. Higher ends computerised balance charger should have a function to change the charging amps. Range and resolutions depends on the charger model. You may like to refer your manual for confirmations.
      hey bro,
      The DN charger is a Lipo only balance charger. I believe there is only one available in local market which comes with the built in balancer (parallel charging).
      Charging amps can be set from 0.2A to 2A in 0.2A increments.
      Hope this helps.
      Practice makes permanent. Perfect practice makes perfect.
        Originally posted by protyne
        hey bro,
        Hope this helps.
        hey thanks! it helps!
          so meaning to say, any chaarger tht has the inupt to connect to my batt's balancer tab, is a balance charger? thanks in advance
            i would think so. the tab is only used for balancing. had a tahmazo tl4 before, it charges this way.
