Settings for charging small 3s Lipos with DN Balancer/Charger
    Hi all experienced Lipo users,
    I recently got a DN Balancer/Charger from Jet Hobby and use it to charge my small 3s Lipos with balancer tabs. Am not sure what the correct settings should be.
    My Lipos are indicated 1500mAh and 3.7volts. What Ampere settings should I set on my charger? 1.4A/1400mAh(cos my charger don't have 1500 mAh setting)? OR is it to be divided by number of cells (in this case, 3cells) and to set at 0.4A/400mAh?
    Also, I'm using the Lipos on a 1/18 scale Mini LST with Mamba 25 brushless motor. What voltage cutoff setting should i set on my brushless ESC? I connect my Lipos to the Mini LST via Deans Connectors (which means the ESC only sees the 3s as one cell, right?).
