Was going thru' the Wattflyer website and came across this thread http://www.wattflyer.com/forums/show...t=1110&page=11.
Says that the claimed 20C continuous by FP will cause permanent damage to the batt. and reduced capacity with every cycle and even at 15C things do not look good.Excessive temps were recorded. It also shows the same voltage dip at start of discharge as the PQ cells and later on, FP admits that its lipos are actually from Enerland and cells are the same as the Polyquest and Hyperion cells.
A lot of mud slinging between the testers and FP over the claims with FP requesting the thread be closed! Apparently at discharge rates above 10C, cycle life drops a lot to about 20 to 50 charge cycles.
I'm still on the lookout for replacement cells- KP do you have any comments on this thread and any assurances? thanks
