Safe Li-ion Power Source - my new power source
Saphion
MicroHeli-Nut,
Pilot started in Feb 03, and believe the cells was shipping in May 05. It really start getting traction in RC Group in Aug 05. They just got patent in Feb 06.
I just found it last night.
Watch this video if you have not...http://www.valence.com/SafetyVideo.asp
The best thing is the same Lipo charger, ESC, balancer can be use with this cells.
Mine should be on its way and order from www.power-motion.com
They sell individual cells in strip of 6,8,10,12 cells. Very easy to do your own packs.
Jonathan
What will be the recommended pack for my current setup? 3S or 4S; 1P or 2P?
450TH
CC35
TP 3S 2100
no ext. BEC.*~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~*
I am no Expert in 3D nor Sports flying. If you need advices on crashing, I am an Expert!
Active :T-rex450SE like, 450TH 11T & CC35, R146ip, HS65MG*3, GY401 & HS81MG, mH ProFrame & blings, TP3S2100prolite & 7CHP 72MHz mode 2, EOS 7i & LBA6. MiniZ.
Mike
Not proven yet
Originally posted by HelicopterWhat will be the recommended pack for my current setup? 3S or 4S; 1P or 2P?
450TH
CC35
TP 3S 2100
no ext. BEC.
From specification using KC spreadsheet....you should use a 4S Saphion 1100mah to get a performance between an 3S to an 4S TP. But you will scarfied for flight time.
The jury on flight time is not clear looking at the specification alone..... we all know what happen when you push you Lipo too much what will happen. And also the saphion seems to be able to handle the discharge voltage...
I would take a bet that 4S saphion 1100mah cell (18-20C cont and peak 30C for 30sec ) would be between 3S and 4S TP2100 while only lost 30% flight time. And also much long cell life then TP2100.
Pricing:
- TP2100 3S at $126
- 4S Saphion 1100mah at $52 ( US$8 per cell @exh rate 1.62 )
And the final selling point for me is, it wouldn't burst into flames and release toxic gas in front of my family.
Jonathan
Originally posted by JYHELIDidn't want to wait for the A123Systems and sold off all my Lipo( someone is ahppy
I found an good alternative safe power source but only at 1100mah and weight about30% more then TP.
But is is safe. Check it out.
Battery manufacturer design a large, scalable product line using the Battery Council International standards and form factors
Jonathan
The cell also spec as max 4.2V, so most of the time the cell will be on max charge in this case?
Do share with us your result once you have the cell. Are you getting the p version for high discharge?
Jon,
I'm no batt expert here.... but with the cells made that way, is heat dissipation better or worst compared to the naked lipo packs? I'vve not read ur link yet, 1 more paper to go. And I'm sorry to hear about ur scary incident with the battery. I think if it was me, I'd be very very shaken. I freak out whenever I spark my batts on connection.
extracted post
extract:
"Made up a 4 cell 12.8v Saphion pack with the remaining cells for my Estarter yesterday and flew it today.
At 180 gms The weight is 20gms more than my 8 cell GP1100 pack. But what a difference in performance an extra cell makes. With a Phoenix CC25 and geared Himax 2025-4100 with a 9x4 prop. It draws around 18Amps WOT and the Estarter does unlimited vertical from ROG. This is an Estarter with attitude."
Dt8666
Originally posted by DT8666Hi can share how much they charge for shipping? and they accept Visa?
4 working days in transit expidited service £64.66
To me US$8 is a good deal for shipment, cost of 1 cell.
Note: I just order yesterday and Simon was very quick in my enquiry of express shipment. Response in 12 hours.
A lot of your previous questions was answer in the 29 pages of posts...just didn;t have time ogo through the righ one and point it out to you.
Jonathan
Caution
A word of caustion, always have those handy fire-extinguisher ( you can get from SIngPost) around when dealing with Lipo at home. I used it to put out the frames..and be very careful the real big frames happend a couple of minutes after the intial frame.
There is only one power soucre for me now after the incident. And the only statment that need to convince me from my wife is "It is good that you are at home when the Lipo burst out, can you imagine when this happen the kids are only one at home".
Enjoy your hobby, but do take precaution.
I do want to point out that so far all incidents I have on Lipo ( yes...this is the second time, first was a quick short circuit when I am alone ) was due to mis-handling.
regards,
Jonathan
Power-Motion vacation period
DT8666,
In case you want to place order.....take note of their vacation. Go this through email exchange with Simon.
Simon Sheldon
Amberjac Projects Vacations 2006; 5th to 12th May and 24th July to 8th August
Director
Amberjac Projects Ltd
Unit 14, Henry Bells Yard
Dysart Road, Grantham
Lincolnshire, England
NG31 7DB
regards,
Jonathan
