Using Bullet Connectors For Lipos?
    Why is everybody using deans for lipos? It's so difficult to solder, difficult to plug and and detach as well. why nobody use other connectors like bullet connectors or something? Is it due to some electrical limitation that we should only use deans for hi amps?
    Thanks
    bullet connector
    It's more like wrong connection or battery leads red touches black... POOF
      can share charger easily on the field also, if connector is the same
      35.150
        But then again, if you connect one male and one female this won't happen because with bullets you have to use the rubber shrink wrap
          but u can accidentally short 2 lipos together cuz u can plug one lipo into another. Soldering deans need experience. Solder more soon it will become very easy. If ur soldering is good u can tug on the wires a little to help u plug the dean out and its good tat they are tight so tat it wont come out in flight.
            sometime its just about safety. believe you have heard/seen stories about lipo fire/explosion
            i too have a hard time soldering, but how often do we solder anyway.
            XRB SR Lama
            Robotis Bioloid
            Robot Bear
