newbie here, let's say i wana do charging of my batts at field, i must get how much capacity sla? Any recommendations on shops & price? I've read thru the forum, found dat must get 12v ones but how about the mah?
Sla
Originally posted by FL330The one that I usually use is 12V 7AH. I think it is sufficient for your use. You can get it from Sim Lim Tower Basement shop at about S$17-18.
Originally posted by mugenrsgso any sla 12v 7ah & ABOVE is enough to charge 2-3s lipos outfield? Maybe charge about 4 lipos? Enough? Which brand is more reliable huh?
How big the capacity of the sla batt depends on what capacity battery you going to charge. For those sub 1000mah lipos, 7ah should be alright. For those 2000mah pack, suggest you go for bigger ones like 12ah, should be less than $25. Don't really think brand matters lah. If you really going to charge 4 lipo packs at the field, wouldn't it be better to use your car batt? Got people mention that sla if go deep discharge will die very early.
btw, out of curiousity, how do you actually have the time to charge 4lipo packs at the field?
