I have been keeping this well made EDF for quite sometime so decided to test them out.
1) The wemotec480 with Typhoon EDF 3W .(3.020Kv/V) using 3S 2250mah=19 amps at 30440rpm
2)The wemotec480 with Typhoon EDF 3W .(3.020Kv/V) using 4S 25C 3700maH=30amps at 39200rpm
Going to check out the fan performance using 4s setup on the 900mm Wingspan Mugi .
Initial test shows that the thrust is very strong at max power.
More the next time.
More the next time.
