Please help to identify. Thanks.
    Good morning everybody!
    I am newbie and just started learning about electronics and soldering.
    I would be greatly appreciated if some one knowledgeable can help me identify electronic part I need for my project.
    It supposed to be a 15Hz pulse or frequency generator (I am not sure). It has blue LED that reflects frequency pulsation rhythm.
    This part is tiny and powered by 9V battery.
    I have attached picture of this part for your reference.
    Basic Circuit:
    Components:
    1. Timer IC 555 (TL555 or NE555)
    2. Resistor 22K (R1)
    3. Resistor 470K (R2)
    4. Capacitor 0.01uF
    5. Capacitor 0.1uF (C1)
    This should give you a frequency of 15Hz.
    If want to connect a LED to the output, need to place a resistor in series with the LED.
    Value of the resistor from 330 to 1K (depending on the supply voltage and brightness you want).
      Originally posted by nb8686 View Post
      Basic Circuit:
      [ATTACH=CONFIG]146010[/ATTACH]
      Components:
      4. Capacitor 0.01uF
      Thank you for prompt and comprehensive explanation! I am very appreciated.
      Can I buy it from somewhere already assembled to save time? What is the the name of this thing?
      Thanks.
        You can try Sim Lim Tower.
          Alternatively, you can buy a cheap micro-controller board, write a simple program to generate the 15Hz output.
          Such as this one:
            Lazada is selling the 555 pulse generator module.
              Such as this one:
              [ATTACH=CONFIG]146014[/ATTACH]
              I will try to search at the Sim Lim Tower tomorrow.
              Thank you very much nb8686!
