WTS: Props, Prop adaptors, and Wheels!
    THIS POST GOT EATEN UP AND DESTROYED, I SPENT 2 HOURS MEASURING SHAFTS AND DIAMETERS WITH CALIPERS AND TYPING THIS OUT ON MY PRECIOUS SUNDAY AFTERNOON, ARE YOU KIDDING ME!!!!! I HAVE TO MEASURE IT AGAIN?!?!?! NO AUTOSAVE?!?!?!?!?!
    Ok, but enough of that.
    PLEASE READ HOW TO DEAL.
    • SMS me. Don't PM. My number: ninety-eight, 24, ninety, 10.
    • Quote item number below.
    • Self collect at my place.
    1. Props for IC engines - $3 each. These tend to have thicker hubs and weigh a bit more than electric props. You can run them in your electrics but the additional weight will affect spool up. Overall current draw doesn't seem to be much affected at all.
    2. Xoar 14x8. 6mm shaft hole.
    3. APC 6.5x6.5. Seems to be a 4.5mm shaft hole.
    4. APC 8x4. 6mm shaft hole.
    5. APC 7x9. Seems to be a 4.5mm shaft hole.
    6. Electric props - $3 each. Don't try to use these on your IC engines, they might fail!
    7. GWS-style slow flyer 9x5, NIB. Comes in a pack of two, price includes both.
    8. Unknown brand slow flyer 8x4.5, NIB. Comes in a pack of two, price includes both.
    9. Unknown brand slow flyer 8x4.5, with carbon for stiffness. One is used, therefore one left in pack.
    10. APC 8x6E, NIB.
    11. APC 13x6.5E, NIB.
    12. APC 13x8E, NIB.
    13. APC 8x3.8 slowfly, packet opened but never used before.
    14. APC 6.5x5 pylon racing prop, NIB.
    15. APC 16x8E, NIB.
    16. APC 6x5.5E, NIB.
    17. EMP 6x5, packet opened but never used before.
    18. TGS 14x7, NIB.
    19. APC 8x8, packet opened but never used before, let me know if you need the APC shaft adaptors.
    20. Turnigy 14x8 wood, new. 5mm shaft hole.
    21. Master airscrew 6.5x4. Never used, but out of packet.
    22. Master airscrew 7x4. Used a couple of times, no damage.
    23. APC 15x6, used once, tiny chips on one side.
    24. APC 12x6, used once, no damage.
    25. Turnigy 14x7 wood. I have TWO of these. One is BNIB, one is opened but unused. Shaft hole 8mm. This listing is for the BNIB one.
    26. Turnigy 14x7 wood. This listing is for the opened one.
    27. Folding props - $3 each. Not sure why I have these.
    28. 6.5x4, for 3mm shaft. I have TWO of these. One has its blades reversed for pusher configuration. You'll want to reverse it back for tractor configuration. Never used.
    29. 6.5x4, for 3mm shaft.
    30. Prop adaptors - $2 each.
    31. 5mm prop shaft, 3mm motor shaft, collet style.
    32. 6mm prop shaft, 4mm motor shaft, collet style.
    33. 6mm prop shaft, 4mm motor shaft, collet style.
    34. 6mm prop shaft, 4mm motor shaft, collet style.
    35. 6mm prop shaft, 3mm motor shaft, collet style.
    36. 6mm prop shaft, 3mm motor shaft, collet style, blue anodized.
    37. 6mm prop shaft, 3mm motor shaft, grub screw style.
    38. Wheels - $2 per pair. I had axle shaft sizes here, but it got deleted and I don't care now. Most of the holes are small so you have to drill, but it will be fine for wire landing gear. Use a drill bit you don't care about, plastic tends to melt and stick to your bit.
    39. GWS 85mm ultra light wheels.
    40. GWS 65mm ultra light wheels.
    41. 32mm, with landing gear wires attached. I think it came from an old FMS mini warbird.
    42. 40mm, white solid hub.
    43. 55mm, white solid hub. This one has 4mm hole, quite big.
    44. 60mm, white 5 spoked hub.
    45. 80mm, grey solid hub.
    46. Dubro Treaded Lightweight Wheel. 57mm, 4mm axle.
    47. Wheels - $3 per triple pack. 3 wheels per pack. All these are NIB.
    48. 45mm. White solid hub.
    49. 55mm. White solid hub.
    50. Wheels - $4 per 5-pack. 5 wheels per pack. All these are NIB.
    51. 45mm. Grey solid hub.
    52. 50mm. Grey solid hub.
    53. 60mm. White solid hub.
    54. 65mm. White solid hub.
    55. Free stuff!
    56. Some kind of folding prop holder for 3mm prop shafts.
    57. Some kind of control horn for large foamies.
    58. Single wheels of 100, 90, 80 and 60mm diameter.
    Pictures:
    IC props:
    Electric props:
    Folding props:
    Prop adapters:
    Wheels in pairs:
    Wheels in 5 packs:
    Wheels in 3 packs:
    Free stuff:
ID:	990466Click image for larger version
    10. APC 8x6E, NIB.
    11. APC 13x6.5E, NIB. RESERVED
    12. APC 13x8E, NIB. RESERVED
    15. APC 16x8E, NIB.
    18. TGS 14x7, NIB. RESERVED
    20. Turnigy 14x8 wood, new. 5mm shaft hole. RESERVED
    55. Free stuff!
      10. APC 8x6E, NIB.
      15. APC 16x8E, NIB.
      31. 5mm prop shaft, 3mm motor shaft, collet style. RESERVED
      35. 6mm prop shaft, 3mm motor shaft, collet style. RESERVED
      55. Free stuff!
      56. Some kind of folding prop holder for 3mm prop shafts. RESERVED
        10. APC 8x6E, NIB.
        15. APC 16x8E, NIB.
        28. 6.5x4, for 3mm shaft. I have TWO of these. One has its blades reversed for pusher configuration. You'll want to reverse it back for tractor configuration. Never used. RESERVED
        29. 6.5x4, for 3mm shaft. RESERVED
        55. Free stuff!
        57. Some kind of control horn for large foamies. RESERVED
        58. Single wheels of 100, 90, 80 and 60mm diameter. RESERVED
          Updated:
          10. APC 8x6E, NIB.
          11. APC 13x6.5E, NIB. SOLD
          12. APC 13x8E, NIB. SOLD
          15. APC 16x8E, NIB.
          18. TGS 14x7, NIB. SOLD
          20. Turnigy 14x8 wood, new. 5mm shaft hole. SOLD
          25. Turnigy 14x7 wood. I have TWO of these. One is BNIB, one is opened but unused. Shaft hole 8mm. This listing is for the BNIB one. SOLD
          31. 5mm prop shaft, 3mm motor shaft, collet style. SOLD
          35. 6mm prop shaft, 3mm motor shaft, collet style. SOLD
          45. 80mm, grey solid hub. SOLD
          55. Free stuff!
          56. Some kind of folding prop holder for 3mm prop shafts. SOLD
          58. Single wheels of 100, 90, 80 and 60mm diameter. SOLD
            Updated:
            8. Unknown brand slow flyer 8x4.5, NIB. Comes in a pack of two, price includes both. RESERVED
            10. APC 8x6E, NIB.
            15. APC 16x8E, NIB.
            16. APC 6x5.5E, NIB. RESERVED
            17. EMP 6x5, packet opened but never used before. RESERVED
            28. 6.5x4, for 3mm shaft. I have TWO of these. One has its blades reversed for pusher configuration. You'll want to reverse it back for tractor configuration. Never used. SOLD
            29. 6.5x4, for 3mm shaft. SOLD
            41. 32mm, with landing gear wires attached. I think it came from an old FMS mini warbird. RESERVED
            42. 40mm, white solid hub. RESERVED
            48. 45mm. White solid hub. RESERVED
            55. Free stuff!
              Updated:
              2. Xoar 14x8. 6mm shaft hole. RESERVED
              10. APC 8x6E, NIB.
              15. APC 16x8E, NIB.
              55. Free stuff!
                Updated:
                10. APC 8x6E, NIB. RESERVED
                15. APC 16x8E, NIB.
                19. APC 8x8, packet opened but never used before, let me know if you need the APC shaft adaptors. RESERVED
                55. Free stuff!
                  Updated:
                  14. APC 6.5x5 pylon racing prop, NIB. RESERVED
                  15. APC 16x8E, NIB.
                  21. Master airscrew 6.5x4. Never used, but out of packet. RESERVED
                  55. Free stuff!
                    UPDATE
                    Renumbered for cleanliness. Original how-to-order instructions are the same, but please use the new numbers! Also, price drop on the props and some wheels: everything goes for $2 each!
                    1. Props for IC engines. These tend to have thicker hubs and weigh a bit more than electric props. You can run them in your electrics but the additional weight will affect spool up. Overall current draw doesn't seem to be much affected at all.
                    2. APC 8x4. 6mm shaft hole.
                    3. APC 7x9. Seems to be a 4.5mm shaft hole.
                    4. Electric props. Don't try to use these on your IC engines, they might fail!
                    5. GWS-style slow flyer 9x5, NIB. Comes in a pack of two, price includes both.
                    6. Unknown brand slow flyer 8x4.5, with carbon for stiffness. One is used, therefore one left in pack.
                    7. APC 8x3.8 slowfly, packet opened but never used before.
                    8. APC 16x8E, NIB.
                    9. Master airscrew 7x4. Used a couple of times, no damage.
                    10. APC 15x6, used once, tiny chips on one side.
                    11. APC 12x6, used once, no damage.
                    12. Turnigy 14x7 wood. This listing is for the opened one.
                    13. Prop adaptors.
                    14. 6mm prop shaft, 4mm motor shaft, collet style.
                    15. 6mm prop shaft, 4mm motor shaft, collet style.
                    16. 6mm prop shaft, 4mm motor shaft, collet style.
                    17. 6mm prop shaft, 3mm motor shaft, collet style, blue anodized.
                    18. 6mm prop shaft, 3mm motor shaft, grub screw style.
                    19. Wheelsris. In Pairs. Most of the holes are small so you have to drill, but it will be fine for wire landing gear. Use a drill bit you don't care about, plastic tends to melt and stick to your bit.
                    20. GWS 85mm ultra light wheels.
                    21. GWS 65mm ultra light wheels.
                    22. 55mm, white solid hub. This one has 4mm hole, quite big.
                    23. 60mm, white 5 spoked hub.
                    24. Dubro Treaded Lightweight Wheel. 57mm, 4mm axle.
                    25. Wheels. 3 wheels per pack. All these are NIB.
                    26. 55mm. White solid hub.
                    27. Wheels. 5 wheels per pack. All these are NIB.
                    28. 45mm. Grey solid hub.
                    29. 50mm. Grey solid hub.
                    30. 60mm. White solid hub.
                    31. 65mm. White solid hub.
                      Up. Please use the new numbers below. Remember, everything goes for $2 each!
                      8. APC 16x8E, NIB.
                      13. Prop adaptors.
                        8. APC 16x8E, NIB.
                        13. Prop adaptors.
                          Latest update is still available!
                            Trying to clear space because room is getting crowded. $20 for the lot. That's $20 for everything that remains in the above list. Good if you want to just grab a bunch of stuff and anyhow try .
                              Reserved; will update if this changes, thanks.
