Originally posted by Mel279
View Post
Powering a Snap P1 Offshore Powerboat
Forgot to lube the flex cable many many, thus total meltdown of the teflon liner in the stuffing tube. Therefore I had to strip out the motor, electronics box and drive hardware. Good thing now, I will not put the electronics box back to save weight. Also opportunity to upgrade the drive hardware. One bad thing leads to many good stuff to come.
Positive Thinking at its best.
The cable looks crooked cos the brass tube got heated up and melted the epoxy that was supporting it in the brace.Originally posted by Battle fury View Postyour cable looks awfully crooked. if i were you i will redo the motor mount position again.
But no worries, I will be re-doing the stuff tube again.
Still the same old set of lipo thou. She was very loose at top speed, lucky I was running her early in the morning so no wind or waves to make her blowover.
Also fix back the rudder. Ready to hit the water.
Looks like more work ahead.
58.1mph.
