Hi all,
Up for sale !!!
DX18QQ almost brand new limited edition for sale.
Used less than 2 flights.. and gave up hobby.
Comes with full accessories and as below:
Included DX18QQ Limited Edition accessories:
– AR12120 12-channel DSMX® PowerSafe™ receiver( BRAND NEW UNOPENED)
– XP8000 X-Plus™ 8-channel expansion module
– 2S 2600mAh Li-Po transmitter battery
– Certificate of Authenticity personally signed by Quique
– DX18QQ Sol de Mayo transmitter case
– DX18QQ microfiber display screen cloth
– Orange-anodized Spektrum™ flashlight
– DX18QQ Special Edition DVD
– Engraved DX18QQ dog tag
– Optional 34mm orange-anodized stick ends
– DX18QQ decal sheet
– DX18QQ neckstrap
– DX18QQ SD card
Exclusive DX18QQ Software Features.
In addition to the unparalleled programming options all DX18 transmitters possess, the DX18QQ comes with these exclusive features:
Direct Access to Monitor Screen
Instead of entering the Function List to view the Monitor screen, you can scroll to it directly from the Main screen using the SimpleScroll™ interface.
Direct Access to System Settings
Switch between Function List and System Settings menus without having to power off the transmitter.
6-Servo Wing Setup
Setting up aileron servos for a Giant-Scale model is even easier with the pre-programmed, 6-servo wing setup that has been added to the airplane wing types.
Expanded Sound Selection Menu
Activate or inhibit specific system sounds without affecting others. L
Pitch Curve for Variable-Pitch Props
A 7-point pitch curve can be activated for airplanes equipped with variable-pitch propellers.
Origin Mixing
Choose to limit the master input of a mix to the stick position of the elevator, aileron or rudder.
0.5% Mixing Increments
Mixing values of less than 10% can be adjusted in 0.5% increments, giving you a greater degree of freedom when fine-tuning control response.
Canard Setup
Canard options (1- and 2-servo) are available under airplane tail types when you select the elevon wing type.
Expanded Avatar Selection
A variety of model avatars are available for all three model types. This lets you choose an avatar that more closely matches the appearance of the model you have saved in memory.
Expanded In-Flight Gain Adjustment Options
You can assign in-flight gain adjustment to either of the levers on the side of the transmitter, the right knob or one of the auxiliary trim switches.
Custom Flight Modes
Assign 5 airplane flight modes to any two switches.
Priced to fast sell: SGD $1,000
PM for fastest deal!
Up for sale !!!
– DX18QQ neckstrap
– DX18QQ SD card
6-Servo Wing Setup
Origin Mixing
Canard Setup
Custom Flight Modes
