Selling Unused Frsky X8R Receiver and SBUS to CPPM Converter
FrSky X8R 8/16Ch S.BUS ACCST Telemetry Receiver W/Smart Port - SGD 46
The X8R supports 8 standard servo outputs, and you can access all 16 channels by using the Sbus line with Sbus supported servos or use a FrSky S.BUS Decoder for the full 16 channels. Or you can use 2 X8R receivers in combination.
Specifications:
Dimension: 46.5mm x 27mm x 14.4mm (1.83" x 1.06" x .56")
Weight: 16.8g (.59 oz)
Operating Voltage Range: 4V-10.0V
Operating Current: 100mA@5V
Operating Range: >1.5km (Full Range)
RSSI output: analog voltage output (0~3.3V)
Compatibility:
All 16 channels require the FrSky Taranis, or the XJT module.
For 8 channels in D8 Mode you can use the FrSky Taranis or XJT, DJT, DFT, DHT and DHT-U modules
FrSKY SBUS to CPPM Decoder - SGD 15
Converts the SBUS signal into CPPM without the need for any soldering. Simply plug into your SBUS receiver port and your control servo and it will decode the SBUS signal to CPPM. A full instruction manual is included with the decoder for easy use.
Specifications:
Weight: 4.1g
Dimensions: 250 x 13 x 5mm
Operating Voltage: 4-10V DC
Max Current: 700mA
Operating Temp Range: -10 ~ 80 (Degrees C)
Interested please kindly contact/whatsapp Chris @ 98005926.
Specifications:
Compatibility:
Specifications:
Weight: 4.1g
Max Current: 700mA
