Hi Folks,
Need to clear space in my hangar again. Letting go a very capable and fun 3D Balsa plane that i flew for less than 10 flights.
Hobbyking EDGE 540 V3. Condition 9/10
You can see the specs here:
I have tons of fun with this. its a 3S set up, power of more than 1:1 ratio, can knife edge, hover, alpha, tumble into a flat and slow spin. Its built very light! Flies much like the 3Dhobbyshop plane that i have too.
I have also reinforced the tail section that is recommended by using flat carbon sticks so it's rock solid.
Its very new with the following specs:
1) NTM 1000kv motor
2) Master air screw prop
3) INO Lab D202 metal gear servos for aileron, rudder
4) Hitec HS82 metal gear servo for elevator
Going to let go at only $140 without ESC. Or $180 together with a Turnigy AE65A esc.
If you buy off HK the plane kit is already USD102 before shipping.
Let me know if you keen!
FCFS.
1) NTM 1000kv motor
FCFS.
