Selling a lightly used MegaWAP V2 board with the following:
- MegaWAP V2 Board - already flashed with Megapirate 2.9 r303 (ArduCopter 2.9.1)
- uBlox Neo-6M GPS
- FTDI Serial Linker
- LCD Module - for field programming with MWC
- Hextronik HC-SR04 Sonar
Brandnew, the above is about S$107. Selling it for just S$50.
Let me know if you are interested: nine-7-5-one-4-3-three-3
Meetup in Tampines or Simei MRT.
Features:
- Supports opensource code from: MegaPirateNG and MultiWii firmware
- Up to 8 motor output
- 6 + 2 input channels for standard receiver
- 4 serial ports for debug/LCD/Bluetooth Module/OSD/GPS/telemetry
- 2 servos output for PITCH and ROLL gimbal system
- A servos output to trigger a camera button
- 6 Analog output for extend device plus Sonar port
- A I2C port for extend sensor or device, also ready for future sensors board upgrade
- Separate 3.3V and 5V LDO voltage regulator
- ATMega 2560 Microcontroller
- ITG3205 3-axis digital gyroscope
- BMA180 3-axis accelerometer
- BMP085 pressure sensor
- HMC5883L magnetometer sensor (electronic compass)
- On board logic level converter
- Use standard pin for IO connection
- Board Dimension: 50mm x 50mm
- Mounting hole: 45mm by 45mm
- Manufacturing according to the standard of RoHS
uBlox 6 GPS Module:
- Pre heat shrink wrap to protect the module
- Rechargeable battery for quick restart GPS lock
- Proper 3.3V circuit to power the uBlox chip
- connecting wires ready for Megawap
- Default setting with NMEA/38400 baud rate
Flight mode for Multiwii
- Acro (default mode)
- Level (auto level)
- Alt Hold
- Head Lock
- HeadFree (CareFree)
- GPS Hold (require GPS receiver)
- GPS Return to home position (require GPS receiver)
Flight mode for MegaPirate
- Acro
- Alt Hold
- Loiter
- Guided
- Position
- RTL
- uBlox Neo-6M GPS
Features:
uBlox 6 GPS Module:
- Alt Hold
- Head Lock
- Acro
- Alt Hold
- Loiter
- Guided
- Position
- RTL
