hi all, upgrading tx so have to sell away my current tx.
this is a very good and advanced transmitter in any programming or whatsoever.its condition is good as new 9.8/10! beautiful big touch screen lcd for easy operations and programming!its a ultimate good tx for both beginners and intermediate users.comes everything together with the manual and the box .
whats included:
1) Aurora 9 (transmitter)
2)optima 9 and optima 6 lite (receiver)
3) Hi-Tec neck strap & weight balancer
4) HTS Voice
5) Temp & voltage sensor
6) Electric sensor station
some specs:
he Hitec Aurora 9 channel, full-range system comes packed with features and programing options. And true to Hitec form, this system arrives to market at an aggressive price point. Do not assume by the price tag that you are getting a sub-par system. It competes favorably with systems that cost a great deal more.
The Aurora 9 is a module-based transmitter, packed with easy-to-use, intuitive software that is simple to program. The generous 5.1 inch display is backlit making it very readable and easy to see in all lighting conditions.
Basic Features
AFHSS 2.4GHz / PPM / PCM compatible (once the Spectra Pro 72MHz module is released)
Easy to Read 5.1 inch, backlit, touch screen
User customizable menus
3 multitasking digital trim switches
Fully assignable control switch, knob, stick and digital trims
8 ball-bearing gimbals with adjustable tension and stick length
Full-sized comfortable hand grips
Selectable control stick mode
Power management system
Standard Programing Features
9 Assignable control channels
3 Model types (ACRO/GLID/HELI) programming
30 model memories
20 Character model name
8 Flight conditions with 10 characters
Throttle lock
Fail-safe
Channel function
EPA
Dual rate & EXP
Sub-trim
Trim step
Servo reverse
Servo speed (Up to 25 sec in each direction)
Servo monitor (monitor & servo test)
8 Programmable Mixes (5 x 2-Point , 3 x 7-point curves)**
Trainer port
ACRO Programming Functions
9 Wing types (6 main wings, 3 flying wings)
5 Tail types (main wing: normal, V-tail, ailevator) (Flying wing: 1 servo rudder, 2 servo rudders)
Quick model options select (Dual engine, retracts gear, airbrake, fuel mixture)
7 Point throttle curve
Throttle cut
Idle down
Fuel mixture
Airbrake
Airbrake to elevator mix
Aileron to rudder mix
Elevator to camber mix
Rudder to aileron mix
Aileron differential
Aileron to flap mix
Camber mix
Flap control
3 x Gyro sensitivity (ex: AILE/ELEV/RUDD)
Snap-Roll (4-Way switching multi-direction)
V-Tail
Delta mix
Ailevator
Glider Programming Functions
9 wing type (6 main wings, 3 flying wings)
5 tail type (main wing: normal, V-Tail, ailevator) (Flying wing: 1 servo rudder, 2 servo rudders)
Quick model options select (motor, retracts gear, airbrake)
Motor control (switch on/off)
Airbrake
Aileron to flap mix
Launch (stick position auto cut function)
Camber mix
Flap control
3 x gyro sensitivity
Butterfly
V-Tail
Delta mix
Ailevator
Helicopter Programming Functions
6 swash types
Quick model options select (governor, needle control, fuel mixture)
7 Point pitch curve
Throttle cut
Gyro sensitivity
Needle control
Swash to throttle mix
Rudder to throttle mix
Fuel mixture
Throttle hold
Swash mix
Revolution mix
Governor
selling away everything for $399 only!
pm to deal!
whats included:
4) HTS Voice
some specs:
Basic Features
30 model memories
Throttle lock
Fail-safe
Channel function
EPA
Dual rate & EXP
Sub-trim
Trim step
Servo reverse
Trainer port
Throttle cut
Idle down
Fuel mixture
Airbrake
Aileron to flap mix
Camber mix
Flap control
V-Tail
Delta mix
Ailevator
Airbrake
Aileron to flap mix
Camber mix
Flap control
Butterfly
V-Tail
Delta mix
Ailevator
6 swash types
7 Point pitch curve
Throttle cut
Gyro sensitivity
Needle control
Fuel mixture
Throttle hold
Swash mix
Revolution mix
Governor
pm to deal!
