MWTSL: Quadcopter 450 V2 with Ardupilot APM2 (Fligh Video attached)
    Selling my Arducopter Testing Platform. Condition perfect, cause never crash
    I have tune the APM2 for stability and lock-in feeling, so its perfect for beginer.
    The specification:
    Frame: 450V2 With built in Power distributor. The arms feel stronger than its twins brother.
    Motor: 2830-920Kv motor
    ESC: 30A Flashed with SimonK FW
    Flight Controller: APM2 loaded with Arducopter 2.6 Delta Firmware.
    About APM2:
    ArduPilot Mega (APM) 2.0 is a pro-quality IMU autopilot based on the Arduino Mega platform, which can turn any RC vehicle into a fully autonomous Unmanned Aerial (or Ground) Vehicle. Depending on which software you choose, it can fly fixed-wing aircraft, multicopters, helicopters, and control ground rovers and boats. It handles both autonomous stabilization and GPS navigation and allows fully scripted waypoint missions and camera control. It supports 8 RC channels, has four serial ports and features an all-in design.
    Features include:
    ?Free open source firmware supports planes, multicopters (quads, hex, oct, etc), helicopters and ground rovers!
    ?Simple setup process and firmware loading via a point-and-click utility. No programming required! (But if you do want to fiddle with the code, you can with the easiest embedded programming toolkit available: Arduino)
    ?Full mission scripting with point-and-click desktop utilities
    ?Can support hundreds of 3D waypoints
    ?Two-way telemetry and in-flight command using the powerful MAVLink protocol
    ?Choice of free Ground Stations, including the state-of-the-art HK GCS, which includes mission planning, in-air parameter setting, on-board video display, voice synthesis, and full datalogging with replay.
    ?Autonomous takeoff, landing and special action commands such as video and camera controls
    ?Supports full "hardware-in-the-loop" simulation with Xplane and Flight Gear
    Hardware includes the following:
    ?3-axis gyros
    ?3-axis accelerometers
    ?3-axis magnetometer
    ?Barometric pressure sensor for altitude
    ?10Hz GPS module
    ?4 Mb of onboard datalogging memory. Missions are automatically datalogged and can be exported to KML
    ?Built-in hardware failsafe processor, can return-to-launch on radio loss
    ?Include relay can trigger any device, can be controlled by mission scripts
    Optional accessories (Not included):
    ?Airspeed sensor
    ?Current sensor
    ?2-way telemetry
    Specifications:
    ?Processors: atmega 2560, atmega 32u2, MPU-6000 DMP processor
    ?Onboard sensors: 6-axis MPU6000 (gyro+sccel), baro, mag, GPS
    ?Datalogging memory: 16MB
    ?Size: 40x65x10mm
    For those who interested, please PM, Whatsup or SMS 900 Three 6034
    I'll do another demo flight for those who still want to see how it perform before deciding to buy (No obligation)
    Be Blessed,
    Up
