Hey i'm selling away my CC-01RTR
Condition:
Test run 3 time (Per run less than 1/2hrs)
Trail 2 time (Per trail about 3hrs)
Has*been on muddy trail ones only.
Tested all electronic waterproof pasted.
Got scratch on body shell on the side n bottom part of chassis,
sure mah due to test run Ha...Ha...
(Full metal ball bearing from Yeah racing)
Front chassis has been cut n DIY front skid plate for slightly better obstacle*clearance.
Rear also cut for body-lift n drilled holes for drop-link suspension set-up for *greater ground clearance.
Electronics included
1)Tamiya TEU104BK ESC (already waterproofed with neutral cure silicone)
2)stock tamiya motor (New silver can) with Yeah racing aluminium motor mount.
3)Axial TX & RX
(AX-3 2.4GHz Transmitter pistol grip)
(AR-3 2.4GHz receiver already water proof using corrosion-x)
4)Axial AS-2 Servo
digital high-torque metal gear*steering servo*already waterproofed with neutral cure silicone)
5)stock rims n tires.
5a) Topcad 1.9 alloy rim n tires.
6) Tamiya light-kit TLU-01(full LED)
7)Yeah racing alloy C-Hub n knuckle .
7)Some spare items inclued:*
1 new set Yeah racing**metal ball bearing.
1 new set plactic gearing.
Not included - Charger & batteries..
selling for $300.*
contact me @ 90113364
Plan to get Axial Honcho for my next project Hi...Hi...
Condition:
3)Axial TX & RX
4)Axial AS-2 Servo
selling for $300.*
