WTS Futaba 3PKS 3-Channel 2.4GHz FASST Computer Radio w/ RX
    Selling the above as I do not need a high end tx. Wheel has been upgraded to metal type. Comes complete with R603FS rx, manual and stock wheel.
    $250 only. Self collect at Hillview Avenue or Shenton Way. PM to deal. Thanks for viewing.
    It's been THE system of choice for drivers of all skill levels; now Futaba takes 3PK technology to new heights with a version that adds even more features and convenience!
    The 3PK Super has all of these upgrades...
    •Redesigned Keypad — with a large, easy-to-use jog button. This one button moves the cursor left, right, up or down; pushing the button in then accesses the function.
    •Vibrating Alert System — useful for monitoring battery levels, indicating Power On and Timer Up, as well as lap navigation
    •Expanded Driver Menu — featuring three levels and a "Big" menu especially for drivers of 1/5 scale and larger vehicles.
    •Throttle Mode Select — for choosing from two servo neutral points: 70/30, which offers more acceleration and less brake for nitro modelers, or the equal acceleration/brake 50/50 mode for electrics.
    •Double the Model Memory — up to 20 models, while still being compatible with the CAMPac module that can add another 10 models.
    The main screen provides a wealth of information instantly: voltage levels; hours and minutes the radio has been on; model name; whether you're in High-Response or standard FM/PCM mode; dual rate settings; throttle ATM; steering and throttle trim settings, and more.
    You'll still find all of the 3PK's most popular features, including:
    With the Advanced Positioning Adapter, the wheel can be dropped or rotated to achieve the perfect "feel" in seconds.
    •Large, backlit LCD screen with adjustable contrast and 128 x 64 resolution.
    •"Direct Select" — single-button access to 8 pre-assigned functions
    •Choice of "New Driver", "Race-Ready", "Big" or "Expert" menus that offer easier programming for sport drivers and more advanced programming levels for competitors
    •Adjuster feature that restores compromised settings to Factory Default
    •Assignable switch and dial functions
    •Two programmable mixes for complex custom setups
    •Digital trims and dials with automatic electronic memory
    •Sub-trims, servo reversing and EPA on all channels
    •Fail-safe and battery fail-safe
    •Easy conversion to right- or left-hand use
    •Double dual rates, exponential and adjustable servo speed
    •Up/Down, lap and system timers
    •Direct Servo Control (DSC)*
    •All this, in a system that weighs only 29 ounces!
    Tx sold to a nice bro..thks for all the interest.
