WTS: RC Lander Hawker Hunter 70mm EDF Jet
    Selling a 2 months old RC Lander Hawker Hunter 70mm EDF Jet bought from rotor which requires only a 6 channel Receiver and designed for 6s 2200mah - 3000mah lipo battery.
    I used a 6 channel mini RX and 2x 3s 3000mah 20c or 1x 6s 3000mah 20c lipo battery to flies this jet. It flies stable and easy to handle but it flies good speed if the missiles removed. I fly 2.30 minutes for always full throttle but 3.30 minutes if throttle management.
    Jet is in good condition and never crash. Selling due to upgrade to big jet.
    Asking for $350
    > Installed 11 micro servo for retract x3, flap x2, rudder x2, aileron x2 and elevator x2
    > Installed LX 70mm 2100kv EDF Fan and ESC which drag 1000watt (measured by eagle power) and generate approx 1.75kg thrust.
    > Installed Navigation LED lighting system. Red led x1, green led x1, white led x4
    > Installed After-burn lighting system which power by a Brushed ESC and control and shared a signal from throttle via a Y cable.
    - Wing span: 866mm
    - Fuselage Length: 1157mm
    - EPO material Body
    - EPO material Wing
    - Pilot
    - Full Metal Anti-Vibration Landing Gear Pre-installed
    - Flaps system
    - Missiles
    NO GEAR DOOR system
