Hi all,
Looking to sell my Align 3G. It is on v2.
Here's some of the specs:
●3-axis gyroscopic flybarless system to simulate the stability of mechanical flybar system, yet at the same time achieving agile 3D performance.
●Utilizes Silicon Micro Machine (SMM) sensors for excellent stability.
●12 bit processors providing ultra high resolution, resulting in highly precise controls
●Software upgradable through PC interface adapter
(sold separately)
●Simplistic setup process without the need of external devices. Setup is done through 5 steps and 2 sensitivity adjustments. Rudder setup is identical to GP780 gyro, minimizing learning curve.
●Flybarless system dramatically improves 3D power output and efficiency, resulting in reduced fuel or electricity consumption.
●Highly sensitive gyroscopic sensors combined with advanced control detection routine providing higher hovering and aerobatic stability than other flybarless system.
●Suitable for all CCPM and mechanical mixing system.
●Comaptible with helicopter of all sizes from T-Rex 250 to T-Rex 700.
●Innovative Pitch Gau as an aid to facilitate pitch adjustments.
●High frame rate signal output for faster and higher precision servo response.
●Capable to operate between 4.5V to 8.4V, compatible with high voltage servos.
●Small footprint, light weight, minimalists and reliable design.
Specification:
●Suitable Voltage RangeC 4.5~8.4V
●Current Comsumption:<80mA @ 4.8V
●Flip and Roll rate detection speed: :±300degrees/sec
●Rudder rate detection speed:±500degrees/sec
●Sensor resolution: 12bit
●Operating temperatur:-20℃~65℃
●Operating humidity:0%~95%
●RoHS certified
●Dimension:
Control box:42x26.5x14.5mm
Sensor:22.3x21.7x14mm
●Weight:
Control box:16g
Sensor:9g
Offer me a price! So... Lowballers, here's your ultimate chance!
PM me if interested!
Cheers!
(sold separately)
Specification:
●RoHS certified
●Dimension:
●Weight:
Control box:16g
Sensor:9g
Cheers!
