Selling my modified Imax 9x (er9x firmware) with following Receiver,
2 x HK-T6A-V2 6Ch Receiver
2 x Turnigy 9X 2.4GHz 8Ch Receiver (V2)
90 sgd. If you are interested, please PM or text me at 96608700
Er9x firmware support the following,
* Up to 16 model memories.
* Multilevel flexible mixer - any input channel can be assigned to any output.
* Mixers can be added, multiplied or set to replace other mixers.
* 8 5pt curves, 8 9pt curves with graphic visualization.
* Expo and Dr for the 4 primary channels, split Left/Right with graphic visualization.
* Throttle trim, throttle expo.
* PPM input from the trainer port can be used as input to mixer.
* Adjustable timer for each model. Can be activated by switches, throttle channel or throttle %.
* Adjustable battery warning voltage.
* Adjustable contrast.
* Adjustable beeper.
* Selectable trim increments.
* Selectable PPM output - 4ch, 6ch, 8ch, 10ch, 12ch, 14ch, 16ch.
* Selectable PPM pulse spacing.
* Limits and offsets for each output channel.
* Offset can be set with stick inputs.
* Stick calibration.
* Graphic or numerical representation of output values.
* Throttle tracing.
* Reverse throttle.
You can download the manual from, http://er9x.googlecode.com/svn/trunk...rs%20Guide.pdf
Regards,
SR
* Throttle tracing.
* Reverse throttle.
Regards,
SR
