10g Digital Servo
    10g Digital Servo
    Hi!
    I am bringing in 10g digital servo in 2 weeks. Here are the specs: -
    Digital servo HDS-877 (PLASTIC GEAR)
    Operating Voltage : 4.8V ~ 6V
    Motor Type : Ferrite brush motor
    Neutral pulse : 1.5ms
    Travel angle : 45~50º at +/-400us
    Speed : 0.11sec/60 at 4.8V
    Torque : 1.2kg.cm at 4.8V
    Dead band : +/- 1us (Adjustable)
    Weight : 10gr
    Dimension : 21.8x11x19.8
    It is made in Korea and sold in USA.
    Price is attractive. Let me know by this week if you require any.
    Regards,
    mack
    I have seen them all.
    A mediocre r/c pilot who thinks that he is one top gun.
    A nerd looking and sick flyer who thinks that he is a great modeller.
    Greed that made a friend became a competitor.
    any pics? and how big is the size? hitec 55? or hitec 50?
    pm me the price
      Here are some brief details comparison: -
      1a/ HS50, 21x11x22, 6.1g, torque 0.6kg, 0.09s/60
      1b/ HES-540, 20x8x17.6, 5.4g, torque 1.0kg, 0.10s/60 (IC servo)
      2a/ HS55, 23x12x24, 8g, torque 1.1kg, 0.17s/60
      2b/ HES-988, 22x9.9x17.4, 6.2g, torque 1.0kg, 0.13s/60 (IC servo)
      3a/ HS56HB, 22.6x11.6x24, 10.7g, torque 1.2kg/6V, 1.0kg/4.8V,0.12s/60
      3b/ HES888, 21.8x11x19.8, 10g, torque 1.2kg, 0.11s/60 (IC servo)
      3c/ HDS-877,21.8x11x19.8, 10g, torque 1.2kg/4.8V, 0.11s/60 at 4.8V (digital)
      The HDS-877 is almost the same size with HS50. Length wise it is longer by 0.8mm and height wise, it is 2.2mm shorter.
      An image of the HDS-877 is attached. Let me know if you are interested in any of the above servos.
      Regards,
      mack
        looks good PM me the price
          I would like to have the price too.
          thanx
          artyspec
          p.s. why dont you publish the price?
            Hi Fuse and Artyspec,
            I would send you the price of the 10g servo shortly.
            Here are some details of other digital servos: -
            Digital servo HDS-577 (PLASTIC GEAR)
            Speed : 0.12sec/60 at 4.8V
            Torque : 3kg.cm at 4.8V
            Weight : 18gr
            Dimension : 28x13.5x28
            Price: ask for quote
            Digital servo HDS-477 (PLASTIC GEAR), Ball bearing - 2BB
            Weight : 29gr
            Dimension : 31x16x30.5
            Let me know if you want any and I would check with the supplier on stock availability of the above 2 servos.
            Regards,
            mack
              Hi all,
              Here is an update of the status of the digital and IC servos.
              1/ HDS-877, digital, 10g, 0.11s/60deg, 1.2kg torque, 2 pcs left
              2/ HDS-577, digital, 18g, 0.12s/60deg, 3kg torque, taken up
              3/ HES-1188, metal gear, IC, 63g, 2BB, 5kg torque, taken up
              4/ HES-490, plastic gear, IC, 4.9g, 0.12s/60deg, 1.0kg torque, testing
              Let me know if you need to order or require more information.
              Regards,
              mack
              Last edited by mack; 16-06-2005, 04:06 PM. Reason: amendment to phrase and descriptions
                Finally, the new 10g digital servo would be here tomorrow. Delivery would be made on Friday and Saturday. All fellow flyers who made their order would be contacted soon. Thank you for your patience. Appreciate it.
                Kind regards,
                mack
                  I am currently running it on my Trex tail with out any problem. I worth the money for a digital servo.
                  FLYING IS FUN.
                  Stratus, Trex 600 NSP, Swift 16
                    Thatz the new 10g digital servo that I also have some in stock. How much did you pay for it?
