For Sale Big Dave Designs experimenters kit for the Revell Type V11C 1/72 submarine
No time to work on this. Its is slightly started in that the centre caps are epoxied together and the air inlet outlet tubes are in place,
Price NEW was US $75 (As you can see from website the kit is now US $165, but basic kit now includes some of the additional parts listed below as well as some pre assembly)
I’m selling for Sing $75, and in addition to the basic kit, I have also included the specialist parts needed.
Basic Kit contains
2 x 2” Tubes
1 x 1.75” Tube, with bulk head already cut and epoxied in place
2 x end caps
1 x centre cap (two end caps with centre hole cut and epoxied together)
1 x CD containing build description and photos of Dave’s build
Additionally I’m including
Ballast pump
Solenoid valve
Air Bladders
Bulkhead seals
From Dave’s build manual
Quote
List of components to be used in Revell Type V11C WTC
1. Receiver
2. 3 x Servos- rudder and dive planes- Bluebird - BMS-371, or Hitec
3. 2 x Motors and gearbox- GWS-GW-LPS-RXC-C
4. Motor-ESC
5. Pitch control- APC-4- Subtech - not needed to get in the water
6. Ballast Pump- Air pump - INCLUDED7. Vacuum Release valve- - INCLUDED8. Micro relay- Radio shack- 275-240
9. Bladder - INCLUDED10. Battery-2-3.7 volt 1 AH Lithium-Ion- A123 will also work well
11. 5 x Bulkhead Seals- BHS-1, - INCLUDED
12. Miscellaneous-Wire, silicone tubing, K&S tubing, plastruct, Hobby shop-Craft store.
Unquote
So as you can see aside from parts readily available in local shops its all here!!
PM me here.
Basic Kit contains
2 x 2” Tubes
2 x end caps
Ballast pump
Solenoid valve
Air Bladders
Bulkhead seals
Quote
1. Receiver
4. Motor-ESC
Unquote
PM me here.
