Clearing the below items at low price. All are brand new in original packaging & not used before. Interested or any query, pls pm me (PM only, pls do not post here). Pick up will be at Bukit Batok.
1) Hi-Torque Servo Saver (p/n: 50473) - 2 set available - $8 each
2) Hi-Torque Servo Saver (Black) (p/n: 51000) - $8
3) Aluminum Horn for Hi-Torque Servo Saver (p/n: 54121) - 2 set available - $15 each
4) Silicone Damper Oil Soft Set (p/n: 53443) - $8
5) Silicone Damper Oil Medium Set (p/n: 53444) - $8
6) Silicone Damper Oil Hard Set (p/n: 53445) - $8
7) 3X32mm Titanium Turnbuckle Shafts (2pcs) (p/n: 53527) - 2 set available - $15 each
8) Clamp Type Aluminum Wheel Hub (6mm Thick) (p/n: 53569) - $20
9) 4mm Anodized Aluminum Flange Lock Nuts (Gold, 5 pcs) (p/n: 53161) - $5
10) Racing Motor Brush Set (Standard Type) (p/n: 53581) - $3
11) LED Light Unit TLU-01 (p/n: 53909) - $40
12) LED Light Control Unit TLU-02 (p/n: 53937) - $80
13) LED Light (ø3 Orange, 2 pcs) (p/n: 53912) - 2 set available - $8 each
14) LED Light (ø3 Red, 2pcs) (p/n: 54009) - $8
15) LED Light (ø5 Yellow, 2pcs) (p/n: 54011) - $8
16) Anaerobic Gel Thread Lock (p/n: 54032) - $4
17) Heat Resistant Double Sided Tape (p/n: 50171) - $3
18) Metal Bearing Lubricating Oil (p/n: 53508) - $8
19) Cera-Grease HG (p/n: 87099) - $5
20) 1510 Ball Bearing Set (2 pcs) (Made in Japan, p/n: 53126) - $10
21) 1260 Sealed Ball Bearing Set (2 pcs) (Made in Japan, p/n: 53065) - $6
No reservation. Only serious buyer need to contact me.
Thanks.
Thanks.
