hi bros,
im selling the following items below for a friend due to . . .
1. 3s1p 2300mah 20c-30c zippy-r with dean connectors 9/10
charged less than 5 times coz used to set up a Mini Titan
1 for $35, 3 for $100
2. Turnigy EDF outrunner motor 3200kv x2 9/10
$40 for the pair
3. EDF64 2.56inch fan x2 9/10
$50 for the pair
4. EDF64 complete set x2 9/10
specs: 3400kv inrunner motor and 64mm EDF fan
$60 for the pair
5. F-14 Tomcat fully built with lighting system installed 8/10
specs: nose was repaired coz my friend's wife broke during
1/16 scale, 120cm length, 124cm wing span, weight 650g
$100 for plane only and $150 with 2 x 3400kv and 64m fan
6. Graupner EDF 60mm 9/10
Specs: use 3.17mm shaft motor like HET 2W/Align 430/MEGA
4.92" long, 3.15" outside diameter, Rotor diameter 58mm,
5 rotor prop blades, 4 stator blades, weight 1.77 ounces.
$70 for the pair
7. Pitts S2-C 3D bi-plane fully built 10/10
Specs: manufactured by 3DFoamy USA (original depron made)
30" length, 34" wing span, weight 200g
$75 for the plane only
for all those interested parties just PM me. .handphone broken
thanks alot for viewing the items in our thread. . .
$40 for the pair
$50 for the pair
$60 for the pair
$70 for the pair
