WTS - Futaba tail rudder servo S9254 & S9253
    Hi, selling the above rudder servo...
    S9253 Spec. - $80
    Control System: +Pulse Width Control 1520usec Neutral
    Required Pulse: 3-5 Volt Peak to Peak Square Wave
    Operating Voltage: 4.8 Volts Only
    Operating Temperature Range: -20 to +60 Degree C
    Operating Speed (4.8V): 0.08sec/60 degrees at no load
    Stall Torque (4.8V): 28 oz/in. (2.0kg.cm)
    Operating Angle: 45 Deg. one side pulse traveling 400usec
    360 Modifiable: Yes
    Direction: Counter Clockwise/Pulse Traveling 1520-1900usec
    Motor Type: Coreless Motor
    Potentiometer Drive: Indirect Drive
    Bearing Type: Dual Ball Bearing
    Gear Type: All Nylon Gears
    Connector Wire Length: 12"
    Dimensions: 1.6" x 0.8"x 1.5" (41 x 20 x 38mm)
    Weight: 1.7oz. (49g)
    S9254 Spec - $100
    Operating Speed (4.8V): 0.06sec/60 degrees at no load
    Stall Torque (4.8V): 47 oz/in. (2.0kg.cm)
    360 Modifiable: Yes
    Dimensions: 1.6" x 0.8"x 1.4" (41 x 20 x 37mm)
    sigpicGround is closer than it appear...
    S9253 Spec. - $80
    360 Modifiable: Yes
    S9254 Spec - $100
    360 Modifiable: Yes
      S9253 Spec. - $80
      360 Modifiable: Yes
      S9254 Spec - $100
      360 Modifiable: Yes
        S9253 Spec. - $80
        360 Modifiable: Yes
        S9254 Spec - $100
        360 Modifiable: Yes
          S9253 Spec. - $80
          360 Modifiable: Yes
          S9254 Spec - $100
          360 Modifiable: Yes
            up
            S9253 Spec. - $80
            360 Modifiable: Yes
            S9254 Spec - $100
            360 Modifiable: Yes
              Clearance!!!!
              S9253 Spec. - $70
              360 Modifiable: Yes
              S9254 Spec - $90
              360 Modifiable: Yes
