Cheap outrunner brushless motor for sale, got quite a number to sell at SGD$40 each. PM me if interested, I deal in the west.
The motor features a 3mm threaded steel shaft supported by 2 ball bearings compatible with GWS shaft and spares. Stick/firewall mountable. Will make that IFO, Slowstick go vertically up! It can swing large props and with good efficiency
Specifications :
Weight : 50g(including stick plastic mount frame)
Weight : 43g(without stick plastic mount frame)
Size : 30(Dia) x 27(L) mm
Max Current: 15 amps
Recommended Current: 9.5 amps
Recommended Voltage: 6-12V
Recommended Props: 6x4, 7x3, 7x4 or 8x4
Lipo battery: 2 cells
Thrust: 420grams
Prop size: 8060
Lipo Battery: 3 cells
Thrust: 523grams
Prop Size: 7035
Thanks for looking
Specifications :
Thrust: 420grams
Prop size: 8060
Thrust: 523grams
Prop Size: 7035
Thanks for looking
