mwts: Fully blinged Minititan. With lots of stuff !!
    Might want to sell my minititan for funding on new project.
    The heli is fully blinged, i.e can bling one i almost completely bling liao.
    Kit contains:
    Full metal head, ie, flybar cage, arms, grips etc. All original TT products except for the flybar cage which is specifically chosen for its easy setup qualities.
    Full metal tail. , ie slider, grips etc etc.
    Metal bearing block
    Electronics: 3 x Hitec hs65Hb servos for cyclic
    Jeti Spin 44 esc. (Very new less than 30 flights on it)
    Scorpion 2221-8 motor
    Metal Swash plate
    Green Paddle for fast cyclic response
    Carbon tail blade
    Carbon Tail Fin
    Metal Tail hub
    Funkey 325mm CF blades (about 30 flights) very good condition.
    Low profile battery tray
    Metal boom brace grip
    Micro Heli metal tail servo holder
    Metal tail pulley set
    Tons of spares :
    Nib:
    Funkey 325mm CF blade ~$50+
    Tail booms (metal) a few pieces ~$10
    Tail boom carbon x1 ~$20+
    Feathering Shaft ~$6
    Main Gear
    Auto Gear
    Harden Main Shaft
    Main Shaft Lock Rings
    Misc Screw Bag
    Carbon Boom Support
    Plastic Tail Blade
    SUS Flybar
    Nomal metal Flybar
    Main rotor hub rubber damper
    Tail drive gear set
    Tail rotor shaft
    Misc bearings bought for the kit, including main bearing block, tail unit etc.
    Many many more cannot remember off hand.
    Brand new canopy, already cut and painted in luminous orange and yellow.
    All original plastic parts changed out from bling process will also be included.
    Batteries :
    3 x Thunder power v2 2200mah (approx 30 flights) ~$100 per pack
    1x Desire Power 30c high output 2200mah (approx 50 flights) ~$50
    Everything, on the above cost a total of quite a fair bit. Now asking for only $650.
    Prefer to sell as a set. If price is met and sold as a set, i will give the buyer an additional freebie.
    Ie, fully upgraded kit including high end jeti esc and scorpion motor plus servos and tons of spares. 3 x lesser than 30 flights thunder power and 1 desire power lipo included.
    Basically with a tx, rx, and gyro set, the above set can set u for a long way to go, fully capable for extreme 3d. And there are tons of spares to back u up in the event of any mishap. touch wood.
    Jus call/ sms aloysious at 96367832 for any queries.
      upzzzz
        upzzzz for u bro !!!!
        His Mini-T can piro...piro-flip...piro-funnel...piro-inverted-funnel.... PIRO-SNAKE.... then a real snake come to see him...
        A good heli with expensive stuff !!!
          Upz alloy Mini-T
          The snake is actually his Sifu Was showing him how to do the Serpent, until the snake smell something coupled with Alcohol Now the snake is really going to show him how to do the Anaconda by bringing in it's Anaconda kaki
            Haha bro, next time when u sit on the bench and the snake come see u then u can do all snake moves liao also. Thanks anyway for the upz.
              Originally posted by tucfaz View Post
              Upz alloy Mini-T
              Alamak like that also kena found out by you, haha, really waiting for the anaconda now if its really gonna help me fly that move. And that blood wine is many years ago liao lah, now must try assam curry snake
                Hello
                Can this heli do Kaos
                  kaos not sure cos never try on it before. But sustain piro flips definitely can.
                    my mini T will be lonely without your sexy bird .................
                      Hahaha, dont worry lah bro fran***, i will get my other bigger birds to protect ur little bird
                        Sold to a nice bro
