WTS Jeti SPIN 44A ESC with Jeti SPIN Box (programmer/flight data box) at only $159.
Singapore Hobby Supplies sells at more than $300 for the combo.
Perfect for 450-size heli like Mini Titan and Trex 450.
Jeti SPIN 44A ESC features:
Built-in 5.5volt Switching BEC (most other esc comes with linear bec which gets hot and cuts-off sometimes)
Multiple Governor feature for Heli
Choose from 3D heli governor or Normal heli governor
Flexible soft start (allows you to set however slow a spoolup you want from instant to super slow like 10 or 20 seconds) so you can reduce stress on your heli parts or make sure everything is ok before you lift off.
Jeti SPIN Box features:
Displays flight data recorded by SPIN 44A ESC like motor RPM, heli rotor headspeed, amp draw and voltage, flight time, maximum temperature etc... Very useful when deciding how to tune/setup your heli for your flying style. Or to find out if anything is wrong with your heli.
Measure Receiver Pulse
Check if your receiver is working fine and has enough power.
Servo Tester
Use to test any of your servos. Useful when you buying 2nd hand servos or checking after crashes.
Servo Tester
