WTS: NIB MKS DS9660 Precise Digital Servo X 3 at $80 each. One of the best and most affordable servo in the RC market for Trex 500, Protos and 500 size heli.
This is a high precision servo which would be best suited for agile and sensitive 3D helicopters. It can be used in a plane, though its precision may not fully be appreciated. Better spec and more precise than a Futaba 9650 or Hitec HS5245MG, the MKS DS9660 is a respected servo in Taiwan, Korea and Japan.
Control System: +Pulse Width Control 1500 usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.13sec/60 degrees at no load
Operating Speed (6.0V): 0.10sec/60 degrees at no load
Stall Torque (4.8V): 50 oz/in. (3.7kg.cm)
Stall Torque (6.0V): 62.5 oz/in. (4.6kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400 usec
Direction: Counter Clockwise/Pulse Traveling 1200~1500 usec
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearings
Gear Type: All Metal Gears
Connector Wire Length: 15cm
Dimensions: 43 x 15 x 28.6mm
Weight: 1.58 oz. (35g)
Helicopters apply with 400 to 550 class (Trex 500, HDX 500, Lepton EX, Logo 400 & 500, Atom 500 and Guai 550.
Whoever interested, give me an offer, I may consider.If interested, please call or sms me at 82889900 L.J
