Ripper Brushless Motor OBL 2924/11
Product Code : [2357]
[2357]
Specifications:
Voltage Range: 6-10cells, 2-3x Li-Poly
KV rating: 1100 RPM/V
Dimensions Dia. x L: 28.5x24.1 mm (1.12x0.95 in)
Shaft Dia.: 3.175mm (0.125 in)
Max efficiency Current: 4-12A
Current Capacity: 14A/60s
Internal Resistance: 180m Omph
Propeller Recomended: 8x3.8, 8x6, 9x6, 10x4.7
Weight: 43g
Features:
-Perfect current capacity for long time flying
-Provides extremely high torque
-Most efficient RPM Value
-Best mechanical design for cooling
-Light weight w/ best performace
-Radial mount set included
List Price SGD 87.30
ESC for Heli Brushless Motor BLC-40 (mini titan) *can use for plane*
Product Code : [8041H]
Thunder Tiger introduces their brand NEW speed controls for brushless motors. The BLC-40 is designed for the mini-sized electric aero-vehicle.
Capable of supplying up to 40 Amps of continuous motor current. Small and lightweight, with a large heat sink surface area. Perfect for the Thunder Tiger OBL series brushless motors. And for safety consideration, there are built-in safety features to prevent accidental motor startup when powering on.
Key Features of BLC-40
-Low battery protection
-Over temperature protection
-Motor timing adjustment
-Brake control
-Throttle response adjusment
-Plane and helicopter mode
-Governor mode for helicopter
-Soft start
-Anti-interference ring
Specification
Voltage range: 7.4~14.8V (2~4S Li-Po)
Resistant: 0.0048 ohm
Continuous Load (5 mins): 40A
BEC Voltage: 5V
BEC Current: 2A
Over Load Protection: Temp. Protection
Setup Procedure: Digital
Governor Mode: Yes
Weight: 27gm
Dimension: 52x24x7.9mm
List Price SGD 85.60
Laser 4 Tx w/ HFS-05MS Receiver and charger 29mhz, Mode 1
Product Code : [Laser4 Tx Rx only]
Laser4 Tx, HFS05SG Receiver and charger only.
Please note: Servos, Rx battery, switch harness are not included.
Available 29mHz
Laser 4 FM Radio System
Introducing the all new Laser 4 FM radio system from Hitec RCD. This reliable, value packed radio was created to replace the soon to be discontinued Focus 4 radio. As you may expect, we loaded this new radio system with great features likes Elevon and V-tail mixing and LED battery indicator.
Laser 4 FM Features
4 channel, FM transmitter, All channel servo reversing, ATV on ch. 1 and 2, Ch. 1 and 2 “elevon” mixing option, Ch. 2 and 4 “v-tail” mixing option, 5 LED power meter, Trainer switch, New ergonomic case.
HFS06MT receiver.
Specifications
Size: 1.46" x 0.98" x 0.71" (36.7 x 25 x 18mm)
Weight: 0.55oz (15.5g)
-FM Single Conversion
-Narrow Band
-Auto Shift for 72mhz (Model: Mini 6s)
List Price SGD 180.00
ESTARTER!
Currently, the above motor, ESC and receiver are already mounted.
all 3 servos are in as well. will throw in a 3S Zippy lipo battery.
RTF!!
Pls pm price or sms to 90697545
[2357]
Specifications:
Weight: 43g
Features:
-Brake control
-Soft start
Specification
BEC Voltage: 5V
BEC Current: 2A
Governor Mode: Yes
Weight: 27gm
Available 29mHz
Laser 4 FM Features
HFS06MT receiver.
Specifications
-Narrow Band
ESTARTER!
RTF!!
